What would cause does lights not to work and all other lights work...can it be just the bulbs.The truck has 130,000
theres actually a fuse under the steering column thats called PRND321 id check that to see if the fuse went out, check your owners manual for which it is but i know its down there bro
2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
alright thanks...
tight man lemme know if it works u can txt me 908-1421
