i recommend going the pcm way. i was using this thermal probe to control the fans but no matter what i did the radiator hose would leak coolant out of were the little wire came out. That and they only have a 10degree range. if you know someone with hptuners you can very easily adjust the low speed and high speed fan on/off to whatever you want. and no probe going into a radiator hose. all you need is 3 relays, some wire, and two pcm pins. and of course, tuning software
1993 GMC Yukon GT, 6.0 vortec, head work, no cats, cai, HpTuned by me, jasper lvl2 4l65e, nbs brake conversion
