Thread: E-fan conversion
    E-fan conversion
    Just installed 05 oem fans with nelson harness on 00 sierra. Not able to set fans to high speed both come on low when at temp. They both turn on high when a/c is on and at temp. Is this normal fan settings or should i be able to set them on high when at temp?
    Nov 2009
    Nope they are working as advertised
    Today 03:25 am 6 stringer o thats a good point, its ok ill just add a blinker fluid cooler
    Today 03:24 AMtruckinL33 that's not a good place for it, you can overheat your blinker fluid with the capacitor
    Today 03:23 AMtruckinL33 i need them for when i go back to 1985
    Today 03:23 AM6stringer i mounted my flux capacitor next to my blinker fluid resevoir
    Today 03:22 AMtruckinL33 me too, right next to my flux compasator!
    Today 03:22 AM6stringer hey gear oil needs to be cooled, i have front and rear diff coolers
    Thanks for the reply
    Mar 2010
    Tuscaloosa, AL
    Yep, they are fine. They really only need to be on high with the AC because the condensor needs lots of airflow to keep cool. The fans on low will keep your engine plenty cool unless you are WOT all day.
