Results 1 to 10 of 12
Thread: power sugaring bad...
    Dec 2009
    DIrty south AZ
    i have a 2004 sierra and it had a bad surging problem. i have a 1000 watt mono block and hids running a duralast gold battery and stock alternator i was wondering what are some options are to help solve the prob. thanks for the halp guys....
    Built 2 Run! 6XX HP/ 6XX TQ
    Done the big 3? Maybe add some additional grounds?
    Dec 2009
    DIrty south AZ
    na havent done it yet. i got the link on how to just need to i guess? think that will fix it tho?
    It certainly won't hurt
    Oct 2009
    huntington indiana
    bigger ground from battery to frame, 4ga. min., optima battery, hi amp alternator,1+ farrat capacitor. a local starter repair shop re worked a stock alternator for me for less than $50, when i got it back i could crank the ac with the hi beams on playing my stereo (1000 watt mono and 800 watt 4ch.) and not move the volt gauge.
    procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
    and ya it will beat a hemi.
    Buffalo or Rochester, New York
    Quote Originally Posted by st8kfinger View Post
    I just learned about this in physics Thursday, *FARAD* is the unit of capacitance. I don't think you want a small fuzzy critter hooked up to your battery. Although funny at first, it would probably make the truck smell weird after a little while.
    Kyle - 2004 K1500 Z71 RCSB 5.3
    - Nelson 93 Octane Tune - LPP Long Tubes + Y - Gibson Extreme Duals - Cut Up Stock Air Box - 10.95 @ 67 in the 1/8 -
    - '05 Pickup Front Brakes - '05 Suburban Rear Brakes - Russel Stainless Braided Hoses -
    - DTRL's Turned to Park Lights - 4-HI Mod - '05 SS Seats -
    - I downshift near hybrids so they can hear me hurting the environment. -
    Racoon Twp., PA
    I will just say it before Quik does Welder shop, welders wire, no need for an alt. Grounds grounds, and more ground. + voltage does nothing if it can't get back to the source.
    2013 CC 5.3
    81 C10 LS1 project
    Quote Originally Posted by tanz45 View Post
    I wouldn't say that JUST that... For every 1000 watts you need 100 amps of alternator is the general rule.
    I also have a few car audio batteries left over if you're interested in buying a spare battery to help.
    Just cut down on the sugar intake for the truck I guess.
    Aug 2005
    St. Anthony, Indiana
    could put the truck on insulin injection.
