Results 1 to 5 of 5
Thread: electric fan ?
    electric fan ?
    I have a 19" fan that i came across that was on a ford powerstroke,anyway my question is it moves 3100 cfm is that enuf or do i need to run duels and move around 4000 cfm to stay cool.
    Nothing stock...I either broke it or replaced it before I broke it!!
    Tyler, TX
    thats alot, its gonna pull about 24-30 amps though, you need a good harness for it
    www.tjc.edu
    you guys runnin' aftermarket setup what size are your fans and do you know the cfm.I know how to wire them and all that just not sure witch fans i really need,some 14" fans say they move 1250 cfm and some are only 850 cfm.i was told that ls1 setups flow about 2200cfm when both are running with a 40amp harness.
    I would like to see more CFM. Where do you live? Do your summer temps get high?
    My Flex-a-lite 292 fans (dual 13 1/2" fans) pull 4600 cfm at 28 amp draw.
    well i just won a dual fan set-up on ebay out of a 99 trans-am,does anybody know how much modification it will take.i figured this would work better than a aftermarket set-up.
