It'll all go away after the next solar eclipse, don't worry...I'm pretty sure it's the solar wind blowing in from space.![]()
99 Silverado ECSB 4X4, LQ4, Patriot Stage 2 243's w/ 59cc chambers, TR224-112, Pacesetter LT's, Nelson tune, FLT Lvl 5, Yank 3k stall, UD pulley, CAI, Ported Throttle body, TB Bypass, 160* t-stat, E-fans, 6'' Fabtech lift, 3'' Summit body lift, 37'' ProComp XTerrains, 4.56's, Zexel Torsen T-2, 4'' Rear shackle flip (no blocks) 13.78 @ 98mph on 37's FTW!
you might try some kind of grounded stainless steel sheilding around the power amplification boxes. It always worked to take the static out of ignitions.
i just installed my HIDs today & checked - yep, they're causing static on mine too.
do you think grounding the relay harness to the engine block will fix this - seein's how the antenna is grounded to the fender/body?
i know it's kinda an out-there idea considering the engine has a ground strap running to the firewall, but you never know sometimes...
I've had ZERO issues with mine.
08 RCSB :: Z71 :: 5.3 :: Flowmaster :: Spectre :: Pacesetter :: Nitrous Outlet :: Walbro
Custom Tuned by a Skinny White Guy
I had read a thread about this a while back before I got mine, and they said make sure the ballasts are mounted to something plastic(i put mine on the plastic grille supports) not on any metal parts of the truck. How true this is, I have no idea, but my reception is fine.
02' 5.3 ECSB| Nelson 93 Tune | 212/218 Cam | LPP lt's w/ ORY | Volant CAI | Magnaflow | 2" Belltech drop | JL audio | 6000k HIDs |
never had an issue with mine.
5.3 224/224xe .566 .566 114, Comp 918 and 7.4, 3200 stall, 8.1 injectors, LT's ORY and no cats, Nelson Tune
I would add a ground to the factory side of the harness. The only way its causing interference is through the wires, its not radiating. I do have static in my CB, but I need to add a better ground to my CB before I say that the HIDs are the whole problem.
mean05: he told me a price and i bent over and lubed up
