Results 1 to 2 of 2
Thread: lq4 or lq9 harness
    Nov 2004
    is there any diference in those two harnesses or pcm and where would be the best spot to find them ? because i find alot of 6.0 but never a harness or pcm thanks alot
    lata seth
    01 pewter extendocab 4.3 bout to have 6.0.
    18'' boss motorsports dubs
    2/4 drop, toneau cover
    alpine cd player, directed tweeters, 1200watt ma audio amp,
    3 jl audio 12's in custom ported box its all show.
    wife has a 99 honda accord with a open filter makes a weird noise sounds like doof.doof.doooof. lol
    yall be easy seth
    There aren't any major difference, even a 4.8 or 5.3L harness will run either one, as long as the throttle body is the same. Some might have provisions for 4wd, different trans connectors, etc. but the engine will run.
    check with hiway auto, not sure if they can help you with that, but it's worth a shot.
    later,
    allen
