07-01-2009, 05:18 PM
Senior Member
gauges died
well i was coming home in the 86 silverado today and all of a sudden all the gauges died. the oil psi pegged volts droped water temp pegged and fuel dropped to empty! im running a aftermarket tach and mech oil presure gauge they still worked fine and the speedo worked fine. im asuming the speedo is cable driven. i tried looking for fuses but found nothing didnt find any burnt up wires or anything so im lost. help please
__________________
03 yukon xl: BUSTED 10-BOLT MOD debadge, intake, tb bypass, clear markers, cleared stock headlights,billet gmc emblem,20% tint, tint tails & third brake light, removed roof rack, custom 3in magnaflow exhaust with 14in muffler and hidden tails, vette servos, Nelson Performance 93 tune
86 silverado k10: 350 4bolt bored 040 214/224 cam 601 heads 9:4.1cr 2800stall 2in lift black rallys lt headers custom exhaust edelbrock rpm intake/600 carb
07-01-2009, 11:41 PM
Senior Member
Ignition switch. Random WAG.
__________________
 2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
07-02-2009, 11:24 AM
Senior Member
No the speedo still works fine thats why i said i assume its cable driven. I pulled out the cd player that was added in lastnight after something shorted out and burnt up some other wireing that the po installed. They bought the adapter harness for the stereo but wired in a bunch of aftermarket under dash lights in with it and i found some bare wires which prob caused the lights to catchfire. All thats out but still havent found my gauge problem yet.
__________________
07-02-2009, 12:44 PM
New Member
probably a blown fuse, burned/broken wire or bad ground. Check the ground and check voltage everywhere its supposed to have it.
Could also be the electrical wiring in the steering column, PITA to swap.
07-02-2009, 01:05 PM
Senior Member
Well i looked and never found any fuses for the gauges like how my cars are setup (82&86) i guess ill have to look in one of those repair manuals to find all the wiring diagrams and such. I do know the colum has been out before when the trans was replaced with a th350 from 700r4.
__________________
07-03-2009, 10:52 AM
Member
On my 78 there is a ground wire for the dash up on the emergency brake brackets and every time it would come off I would have issues with my guages and the lighting for them.
__________________
1992 rcsb k1500 lq4 4l80 swap done.
07-03-2009, 01:25 PM
Senior Member
Ill have to take a look for that when i get back in town. I know im having a issue with the e brake setup at the moment also. Like the cable is stretched or there is a spring or something missing causing the foot pedal to contact with the brake switch.
__________________
