A buddy I work with has a 2001 5.3L GMC Sierra Z71, and has an SES light on. OnStar said the code was P1416, power train something or other. What does this code pertain to, and any fixes you guys have would be a great help?
Thanks in advance,
Steven
Thanks in advance,
Steven
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
Maybe this can help some.
Document ID# 664110
2001 GMC Truck GMC K Sierra - 4WD
DTC P1415 or P1416
Circuit Description
A secondary air injection (AIR) pump is used on this vehicle to lower tail pipe emissions on start-up. The powertrain control module (PCM) supplies a ground to the AIR pump relay, which energizes the AIR pump and the AIR solenoid valve. Engine vacuum is applied to the AIR shut-off valve when the AIR solenoid is energized. The engine vacuum opens the AIR shut-off valve which allows air to flow to the exhaust manifolds.
The PCM monitors the heated oxygen sensor (HO2S) voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during Closed Loop operation. When the AIR system is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, the diagnostic trouble code (DTC) P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 for bank 1 or P1416 for bank 2 to indicate on which bank the AIR system is inoperative.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0111, P0112, P0113, P0116, P0117, P0118, P0121, P0122, P0123, P0131, P0132, P0133, P0134, P0135, P0137, P0138, P0140, P0141, P0151, P0152, P0153, P0154, P0155, P0157, P0158, P0161, P0170, P0171, P0172, P0173, P0174, P0175, P0200, P0300, P0335, P0336, P0351, P0352, P0353, P0354, P0355, P0356, P0357, P0358, P0440, P0442, P0446, P0506, P0507, P1133, P1134, or P1258 are not set.
The startup engine coolant temperature (ECT) is less than 70°C (158°F).
The engine run time is more than 2 seconds.
The manifold absolute pressure (MAP) sensor is more than 75 kPa.
The engine load is less than 40 percent.
The engine air flow is less than 20 grams per second.
Engine speed is more than 900 RPM.
The vehicle speed is more than 15 km/h (25 mph).
The ignition voltage is more than 11.7 volts.
The air fuel ratio is 13.125:1.
The ECT is between 70-110°C (158-230°F).
The intake air temperature (IAT) is more than 2-100°C (36-212°F).
The fuel system is not operating in power enrichment or deceleration fuel cut-off (DFCO).
The short term fuel trim is in cells 5 or 6.
Conditions for Setting the DTC
The HO2S voltage does not go below 222 mV for 1.2 seconds or more.
Short term fuel trim does not go above a predetermined amount.
Action Taken When the DTC Sets
The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails.
The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame/Failure Records.
Conditions for Clearing the MIL/DTC
The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
Important
Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing or replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent water intrusion into the PCM.
Casting flash in the exhaust manifold may restrict the amount of air flow necessary to affect the HO2S voltage. If you suspect this, remove the air pipe from the manifold and inspect the passage.
Using the Freeze Frame/Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame/Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also help determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same Freeze Frame conditions such as RPM, load, vehicle speed, temperature etc. that you observed. This will isolate when the DTC failed.
For an intermittent condition, refer to Symptoms - Engine Controls .
Test Description
The number below refers to the step number on the diagnostic table.
A check valve that flows in both directions causes heat damage to the AIR system components.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Important
Before proceeding with this diagnostic table ensure that the AIR pump is operating and that air is present at the outlet of the AIR shut-off valve. If the AIR pump is inoperative and no air is present at the outlet of the AIR shut off valve, refer to DTC P0410 for further diagnosis.
Install a scan tool.
Idle the engine in Closed Loop.
Turn OFF all the accessories.
Monitor the bank 1 sensor 1 left front HO2S voltage display on the Engine 1 Data List using a scan tool.
Enable the AIR pump using a scan tool.
Observe and record the Bank 1 Sensor 1 (Left Front) HO2S voltage, as the AIR pump is enabled.
Does the HO2S voltage drop below the specified value?
350 mV
Go to Diagnostic Aids
Go to Step 3
3
Visually and physically inspect all hoses and pipes for:
Proper connections
Clamps are secure on pipes and hoses
No kinks, holes, or pinched hoses and pipes
Components with evidence of heat damage
Are all of the above OK?
Go to Step 4
Go to Step 6
4
Disconnect the hose from the check valve at the left exhaust manifold.
Is air present at the hose outlet?
Go to Step 7
Go to Step 5
5
Repair the restriction or blockage in AIR hoses/pipes between the left exhaust manifold and the point where the system branches to both sides of the engine.
Is the action complete?
Go to Step 8
6
Repair the condition found.
Go to Step 8
7
Replace the check valve. Refer to Secondary Air Injection (AIR) Check Valve/Pipe Replacement - Bank 1 .
Go to Step 8
8
Use the scan tool in order to clear the DTCs.
Turn OFF the ignition for 30 seconds.
Start the engine.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC run and pass?
Go to Step 9
Go to Step 2
9
With a scan tool, observe the stored information, Capture Info.
Does the scan tool display any DTCs that you have not diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
Document ID# 664110
2015 GMC Sierra RCSB Z71 5.3
just something i found around the net.
485rwhp/440rwtq SAE
