Results 1 to 10 of 12
Thread: Keep blowing horn fuse
    Oct 2007
    MARION, IL
    So I have gone through about 4 fuses so far. If i honk the horn more than 1 second it blows. Has anybody else had problems with thier horn or is it just me? I don't use it that often but it would be nice to have.
    Feb 2008
    Bowling Green,KY
    haha, dude my truck from GM didn't have a horn! They freakin forget to install it! But check your relay and then all your connections! Make sure your running the right size fuse to!
    5.3,Trsnsgo HD2 Shift Kit,Vette Servo,K&N CAI,Pacesetter Long Tubes,Off Road Y-pipe,Flowmaster Super44,MSD Wires,Fusion Plugs,TB Spacer,TB Coolant By-pass mod,HP Tune,100 Shot Wet Kit,Air Ride Suspension & No Traction what so ever!!!!
    just run a bigger fuse or a paper clip ahhahahah problem solved.....
    Oct 2007
    MARION, IL
    Well luckily it came with a horn. haha I'll check my relay at lunch today. I just thought it was kind of wierd as I have had the truck for about 3 years and it just started this last month. Thanks for the replies. Has noone else had the same problem?
    Oct 2007
    MARION, IL
    just checked my relay. It is good. I guess I have a short somewhere. where that is who knows. I guess I will have to live with no horn unless anybody has an idea where it could be.
    Feb 2008
    Bowling Green,KY
    it can't be to many places! I mean the horn is mounted up front and ran through the engine bay so its not like the wires are ran all through the truck! Mine has wires ran(but no horn) and they stop right below the radiator! Man i don't know, seems like a bigger fuse would help! If not say screw it and get some train horns, haha!
    Apr 2003
    I had the same problem, horn was shorted out. Get a new horn advance/pep boys/napa/wherever to replace the one that's not working at and it'll solve your problem.
    Andrew
    2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
    Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
    just buy a bunch of fuses
    Wasilla, AK
    GM has a TSB about this. Water from driving in rain, carwashes, etc gets into your horns, sits there, and then short circuits the horn. Then your fuse will blow. The fix was to replace the shorted horn or horns, and point the opening of the horn straight down when installing the new ones. GM also came up with a "shield" to help stop the water intrusion. Once you do this, you will never have this problem again.
    Oct 2007
    MARION, IL
    Wow Thanks guys I knew someone on here would know what was up. I'll get a new horn tommorrow and let you know if it fixes it.
