Results 1 to 10 of 24
Thread: Speedometer/ Odometer?
    Oct 2003
    Is the Speedometer and Odometer totally electrical?? Can you unhook one and have the other one still work?
    http://www.danasoft.com/sig/bsnuggs.jpg
    2001 GMC 1500HD SLT 4X4 CCSB 6.0L
    Mac Performance Intake, 05 E-Fans, Magnaflow Catback, Pacesetter LTs w/ Custom "ORY", Comp Cams 210/210 555/555 112 lsa, Comp Cams 918's, Hardened Pushrods, HP Tuners, BB Thermostat mod, TBBP, EGR Delete.
    Not EVERYONE can be a Louisianaian, it's an art form and a gift from God!!
    Treat every situation like a dog; If you cant eat it or screw it-- Piss on it and walk away
    East Coast
    I'm guessing you wanna unhook the odometer.
    1) it can be illegal, check the laws
    2) if its not, and you dont keep track when its unplugged, and you sell it, knowingly with more miles then it shows. That is Fraud.
    They are completely electronic in the new trucks.
    91 s10 - bagged and bodydropped...getting rebuilt
    91 nissan - backhalfed and bagged
    Sep 2003
    Mukilteo, Wa.
    Or maybe he wants to unplug the Speedo to put in an aftermarket one that reads higher?
    '05 Tahoe 2WD 5.3
    Performance Mods: Nelson tune, 4" Volant Exhaust, Dynatech Full Header system, Volant Cold Air Intake, TB Bypass, 305/50R20 Eagle GT IIs
    Appearance Mods: 20x8.5 American Racing Torq-Thrust STs, Billet Emblem, Black Chrome Speed Grille, Removed running boards, door guards, fender caps and badges, and Silverstar lowbeams and fogs
    Cardomain Page> Click
    East Coast
    He could, yes... according to his username he has a 5.3, so i'm guessing newer truck.
    if not.. eletric speedo's, have electric odometers in them that can be set to factory specs b/c the odometer readings are saved on the comp.
    So if that is what he wants, then the speedo includes both.
    San Marcos Texas
    I'm pretty sure they are both seperate. You could probally unhook the part you don't want in the instrument cluster.
    I need to check on this, but I don't think the actual milage is kept in the computer/pcm. I know the miles are in the gauge cluster, but I'm thinking actual run time may just be stored in the pcm.
    What happens when you flash a pcm and send it out, the truck still keeps it's original miles.
    later,
    allen
    East Coast
    Originally posted by farmtruc+Feb 24 2004, 12:46 PM--><div class='quotetop'>QUOTE(farmtruc &#064; Feb 24 2004, 12:46 PM)</div>
    <!--QuoteBegin-Domeskilla
    if not.. eletric speedo&#39;s, have electric odometers in them that can be set to factory specs b/c the odometer readings are saved on the comp.
    I need to check on this, but I don&#39;t think the actual milage is kept in the computer/pcm. I know the miles are in the gauge cluster, but I&#39;m thinking actual run time may just be stored in the pcm.
    What happens when you flash a pcm and send it out, the truck still keeps it&#39;s original miles.
    later,
    allen [/b]
    I was talkn about a truck with an electronic odo.. where at the gauge, it only shows the numbers, in eletronic form.. not lik eyour truck. Or were you talkn about the same thing? Maybe its saved rightt ehre, but i&#39;ve seen acouple guys in Dallas change over to autometer gauges in older trucks with swaps and they got their new gauge to read the same mileage the old one did.
    San Marcos Texas
    Originally posted by farmtruc+Feb 24 2004, 11:46 AM--><div class='quotetop'>QUOTE(farmtruc &#064; Feb 24 2004, 11:46 AM)</div>
    later,
    allen [/b]
    Ah I forgot you have the digital odometer. It reads the milage off the PCM like farmtruc said. I was thinking the electronic analog odometer.
    Oct 2003
    LaPorte TX
    hate to tell you this but even if you unhook the odometer adn run around for 2, 3, 4 or how ever long. when you plug the connector back into the odometer it will read exactly how many miles you have on it.
    we tried this on my buddies and lets just say he did it for nothing.
    2010 Camaro 2SS/RS
    2020 GMC Sierra AT4
    East Coast
    Ah.. see.. so the computer still reads/saves it and then when you plug it back it sends it? Explains a lot. So he can still change out the gauges if that is what he wants, b/c he&#39;ll always have the right odometer settings.
