Anybody manage to make the factory truck cruise control work with an LS-1 swap? When I first did mine i just wanted to get it running but had thought that this might be possible. So what do you guys think?
1 ton, 4600 pounds, 14.3@94mph any questions?
gmcwantsls1 started working on his, i'm not sure if he's done, but he's the guy you probably want to talk to.
later,
allen
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
I used the 2002 Camaro cruise unit. I think I have one wire to connect up still. I need to finish it soon.
I was thinking it might be possible to just take the original truck cruise control module and use it. But now that I think about that it wouldn't work because the truck has no speed input.
i never even thought of this.......if I get a complete car it should be pretty easy to integrate the stock f-body cruise into the system shouldnt it?
It is pretty easy! the f-body cruise has a really long throttle cable so you can mount it almost anywhere!
