I am putting LT1 fans on my 01 Silverado and I have no blue #42 pin. My truck is supposed to be programmed to use this pin with LS1 edit. My question is can I put a pin in this place and connect directly to it?
http://img.photobucket.com/albums/v6...nstruckls1.jpg
05 Joe Gibbs RCSB 5 gear
99 Vette / 6 gear
02 Honda Goldwing
00 Hayabusa
Well I will answer this myself, I installed a pin in the blue #42 socket and it worked like it was supposed to, the fans kicked on at around 185 deg. like they were supposed to and when the temp dropped to around 175 they kicked off. I guess the truck pcm's are not equipped with this pin but the cars are.
99 Vette / 6 gear
02 Honda Goldwing
00 Hayabusa
Are you using a car or truck PCM? AFAIK all you need to do is add that pin to the wiring harness.
I am using the stock truck PCM and adding the pin fixed it.
99 Vette / 6 gear
02 Honda Goldwing
00 Hayabusa
hey buddy where did you get the pin and does it have a part number. thanks![]()
formerly 02denali 12.79@107
Hey 02Denali, I have tons of those pins. If you can wait till you come down here for Allen to do your cam then you can have a couple.
Bandit!
Jason B. Armstrong, L1, AAM
http://www.danasoft.com/vipersig.jpg
My Efans are hard wired with a temp sensor stuffed in the radiator. This sounds like an easy mod I need to get done! I assume I need Allen to add the features to the tune with the LS1 Edit, though.
Because It Must Be Brent!
2003 Victory Red Silverado SS
14.64 @ 91.78 on a 2.16 60' time even with my big frame driving! (5445lbs)
MODS:
Nelson Performance Tuned / TransGo shift Kit w/ Corvette Servos / ASP Under Drive Pulleys / Flex-Lite E-Fans / FlowMaster HD Trucker / Thermo-Tec wrapped manifolds to X-pipe / 1.5" dropped using Belltech 6400 kit & 6.5 turns on torsion bars / Tinted Windows / Victory Red Spray in Bedliner / Drk Walnut Wood (steering wheel, console, and door inserts.)
02Denali----------I robbed a pin from another harness I had and it sounds like
Bandit can fix you up.
mustbbrent............Allen programmed my computer for the e fans and they work
fine
99 Vette / 6 gear
02 Honda Goldwing
00 Hayabusa
cool bandit i will do that
thanks.![]()
hey bandit i will be in SA this weekend at allen's. let me know if you can get me that pin or two.![]()
