Results 1 to 10 of 38
Thread: LM7 5.3l question
    LM7 5.3l question
    I am currently looking to do a swap to a 240sx, but I am trying to find some useful threads in which it gives me an idea of what turbo to use to achive 500-525 whp on a stock engine w/ pump 91 gas? Can anyone please help?
    Birmingham, AL
    theres a good 70mm for sale here...
    id say that will do the trick
    01 Silverado
    What mitch said. I made 440/411 on a GT67/.81 on my stock internal 5.3. Small LS6 cam or GT2-3 with the 70mm and about 8-12 pounds of boost should get you there
    Feb 2009
    mississippi
    hey man i was gono do that but i found a cheep ls1 and t56 so yea haha but any way im goin with a t70 rear mound lookin for about 15lbs of boost i was wontin 18 but don think that turbo will do it but any way check out these threads
    http://www.ls1truck.com/forums/power...-go-18psi.html
    http://www.ls1truck.com/forums/power...-go-about.html
    http://www.ls1truck.com/forums/v8-co...t56-240sx.html
    So an LM7 can handle 12-14 psi on pump 91 octane gas, that sounds to good to be true? I figured 8 psi would be the max is that wrong?
    I'm runnign 12 with no problems. It's all in the tune. Up to 10lbs and you need pushrods and stiffer springs for added insurance
    how much did you dyno?
    440/411 on 12lbs
    Feb 2009
    mississippi
    quik is runnin 18psi on his 4.8 with just lower comp heads and arp rod bolts i plan on gettin arp rod bolts head studs and duel valve springs and im runnin an ls6 cam witch i would look into if i were you its a grate boost cam
    Spring, Texas
    Quote Originally Posted by ma.racing View Post
    Don't forget to check out this thread too!!
    http://www.ls1truck.com/forums/sale-...-70-turbo.html
