Well i just got back from the dyno thats here locally.
I was a little dissaponted with the results i belive this was with about 10 psi
the best one i did was 471HP and 514FtLb
http://i129.photobucket.com/albums/p...9/treyDyno.jpg
thats about right. My dads ss with 10 psi made around 455 hp. and it has the rear mount gtk 850. good numbers
single digit street truck
for build info
Thats about right. Mine made 475.5 and 520tq with 10 psi on the sts.
12 Sec. Club! SOLD
SOLD***
that truck is dangerous if that is the correct AFR. feed the truck some fuel and you might pick uo some numbers
I would be proud. Sounds right to me.
there is something wrong for shure...lq9 and 10# of boost sould get you around 550 hp...we got 550 outta my lq4 on 10#.
if that a/f is right on the sheet it needs way more fuel for shure before you pop a piston....contact allen for a good dyno /street tune before you blow that thing up.
'13 silverado LT...stock
'11 lt 4x4 z71..tvs1900
Dynojet #'s are usually high too...man...that's leeeaaannn...
●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
