Results 1 to 10 of 14
Thread: 6.0L dynos over 700hp.. corrected:)
    Oct 2006
    Wichita Falls Tx.
    Here is what Jared from Colorado. Running a street stalker kit with a 76MM ball bearing turbo. .68a/r. The power just Drops after 4500 rpms. Using a .96a/r would move the rpm curve alot higher.
    The Density Altitude was over 8000 ft. ...
    Jared
    "Well her you go. Temp was 70 deg, and DA was a sweltering 8630'. I decided to run the pulls in 3rd gear with the converter locked. I really wish I had the .96 AR you can see by the pK HP @4500RPM that Im really getting choked up top. I managed 16PSI with the boost controller all the way up. I have a 14PSI spring in the w/g. Injector duity cycle was @96% AFR 11.8-12.1, timing was at 17deg. 91 octain with 25% E85 mix. No meth. Made 581HP/693.3lbs uncorrected raw power. Corrected to sea level was 712HP/850lbs. While they were strapping it down on the dyno, I over heard them laughing about the mid 11sec 122MPH Gtech passes like they thought I had a suprise comming. After the 1st pull I saw jaws droppThey were all floored to say the least. They dynoed a few procharged, trucks that made 330-350, and a few hopped up cobra mustangs that made 350,s. "
    This is the corrected numbers.
    Here are the real numbers.
    Simply the best turbo kit for late model GM trucks.
    Custom fabrication to fit your budget and needs.
    Dealers for Precision, Comp. & Magnum turbos.
    Online Store
    [/CENTER]
    Apr 2005
    What are the specs for motor & trans?
    Hella lotta power there fo sho!!
    Gone, but not forgotten!
    Jan 2006
    Good Numbers!
    I wonder what mine will run on the dyno? I have a .96 A/R? My turbo is not a BallBearing, but its a T76.
    Hum, I need to get it dynoed.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Quote Originally Posted by SCIV View Post
    Specs ? ? ? Video ? ?? ? ?
    -02 6.0l 40K miles
    -Stock heads, and bottom end
    -Custom ISKY 212/212, .539''/.539",114 deg lobe center.
    -Isky valve springs. 160LBS on the seat/360LBS open.
    -Stock rocker arms.
    -Stock truck intake, TB, and MAFS.
    -68LB injectors.
    -Trick Hot pipes, with 3'' single exhaughst.
    -Nelson A to A intercooler.
    From Pt.net that he posted
    99 RCSB Sierra 5.3
    GO: Doug's LT Headers Polished Magnaflow Muffler, NGK TR6IX,160 Degree Thermostat,EFI Live Custom Tune by Chuck of Corvettes of Westchester, AEM Dry Flow Intake
    Colorado Springs, CO
    Quote Originally Posted by 99LoweredSierra View Post
    -02 6.0l 40K miles
    -Stock rocker arms.
    -68LB injectors.
    Correct engine specs.
    The rest of the truck is:
    -03 Rc,4x4.
    -4L80E with transco shift kit
    -Pro Yank 3400(locked)
    -25% E85 mix.
    Quote Originally Posted by Jamest View Post
    Good Numbers!
    Jamest
    My truck ran stronger with the .96AR. The only reason Im running the .68 is because Turbonetics shipped my turbo with the wrong Ex housing.
    excuse my pretty newb question, but these were rear wheel numbers? if so that is awesome, how streetable is this setup? im trying to learn the ins and outs of all this turbo stuff now.
    May 2007
    Las Vegas, NV
    wow
    S.A. Texas
    probably a dumb question but what is a street stalker kit i have googled it but nothing
