wonder what my little truck runs at the track or hp # ,01 5.3 cam,headers,tune 4.10 gears 1997 s-10 any help?![]()
I would probably guess in the mid 13's maybe lower. Hopefully you can hook up because if you break out into the 12s that would be sick.
Track=13.3 - 13.7
RWHP: ~325
more info, you 2wd? rcsb? wat cam?
i would think you would be doing high 12s if its a 2wd rcsb, there really light
it should go an easy 12.8 with good traction.
my old S-10 went 12.5 with slicks. it had a 327 small block in it.
yes 2wd reg cab told an z06 hot cam!!!![]()
ran a 13.1 at 104 spinnin 2.0 60ft !!!wanted a bit more
not a bad place to start, work on the suspension and there is probably an easy .50 to maybe a full second left in it if you can get the 60ft down in the 1.5 or 1.6 range.
Mid-13s w/ a Z28 (.500/.500) cam or Z06 (.550/.551) cam. I'd say high-13s w/ the stock 4.8/5.3/5.7/6.0 cam
2004 Silverado
1957 Chevy truck
1953 Ford sedan
1924 model T 2dr hard top
