Results 1 to 10 of 23
Thread: Breaking up under boost
    Ponca City
    Question Breaking up under boost
    Been fighting this breaking up and can't figure it out. It's reacting to changes in plug gap, fueling and timing. Some things make it worse. Some better. But it never pulls clean as soon as it breaks over into boost it acts up.. Iv been from 11-22* timing. Fueling from 11.0-12.0afr. Plug gap from .020-.028. Tried tr6 and br7ef plugs. Runs fine until it breaks over into boost. It's on 8lbs. Doesn't matter if its 2500 or 5500 rpms. Same breaking up.. Runs completely normal until it gets in boost. Ideas??
    Slowest in Oklahoma...
    Shitty plug wires? Coils getting weak?
    Ponca City
    Brand new wires. Also swapped coils from my other truck. No change. The coils are relocated to the firewall though. A buddy thought might of been a bad ground to coils. But ran a ground straight to them with no change
    Everything you listed are good things to check and adjust; they all seem correct.
    I had the same situation with my truck a while back with a new set of heads.
    Turns out a couple of the valve seats weren't 100 percent and as soon as boost came in I'd hear small backfires and stumbling. Just like when the plug gap is too wide.
    I know you'll hate to hear that but just a possibility.
    Ponca City
    Now that would suck. Any way to tell which side or way to tell without pulling heads? This isn't a small backfire and miss. It's pretty bad lol
    You'll need to perform a leak down but that probably won't tell you which one because all cylinders will be very close.
    Forget doing a compression test; too general for something so specific and sensitive; only when in boost.
    To be honest my truck was fine before the new set of heads and the new heads were the only change so...
    Pulled the heads after a leakdown wasn't good enough, flipped them, filled chamber with water and watched them leak.
    Ponca City
    Dammit....
    Arizona/Utah
    I have heard of the spark getting blown out under boost, but if you have tried closing the gap it doesn't sound like the issue. I know some plugs are designed for this type of issue to protect the spark, but I will try and find the thread from pt.net.
    Sep 2011
    I was troubleshooting the same issue on my 5.3 when I melted #7. When I tore it down I found 2 exhaust leaks at the manifolds that I never aware of. I'm not sure if that was part of my problem or not but it sure makes me wonder.
    99 rcsb silverado...... boosted.
    He's only pushing 8lbs and has the gap set small, even stock plugs gapped correctly won't blow that out.
    I think ur referring to the plugs that have the unexposed tip, like the tr7/9?
