What's the voltage supposed to be at the pump? There are two grounds, one on the back of the block also a direct ground that grounds to the frame next to the bed mount...And am mistaken or is there no filters outsid of the tank on this year?
Slowest in Oklahoma...
I'm not sure on that truck, mine is in the frame just up from the tank, 12 volts runs the pump, also check n see how many amps r on that same wire. Check the power and ground, then power and ground to the frame. Should be real close to the same. If not its a ground issue
Says GM decided ur truck didn need a serviceable filter, so the put it on the pump, the sock n my tank was pretty nasty when I changed the pump, can't say it burnt it up for sure but I'm sure it didn help the cause
Suburban Fuel Pump Woes
1996 Suburban;
After 3 fuel pumps, numerous harness upgrades, fuel pump relay and new grounds installed, the problem was discovered during the 4th pump install.
Had to replace the sending unit. The connection on the bottom side of the mounting plate (black wire to pump), was weak and caused loss of power, ( it had even gotten hot enough to start to melt the pigtail on the underside of the plate). Hope this helps alot of you out there!
Hope this helps I got it off Chevy truck forums
Checked the sock filter. Looked new. But swapped another in. So rules that out. Will check the voltage to see what is comes out. Just baffling why literally drive it home one night it's fine. Next day head to work and bam nothing...
I'm wandering that to
sounds like a bad pump, walbro pumps are pieces of shit, ive had 4 pumps in a row right out of the box that were faulty
I don't have time to read the entire post, but we just had a few walbro's fail.
take it out, use your fuel regulator, test it on the bench with a bucket of fuel.
We were surprised to see how they acted when they went bad.
I'm starting to give up on walbro.
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Update. Testing the voltage at idle it's jumping from 2-18 and everywhere in between..
