Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 37
Thread: New build high oil pressure concern
  1. #11
    good to know, im deffinitely ready to unleash this Btch, think ill do one more 100 mile city drive hitting the throttle more often then change the oil and go from there.
    come on now, get on it!!!
    I know you've see a new engine build put on an engine dyno before. They make sure there are no leaks, run it up gradually.
    Then dyno the hell out of it!
    It's gonna break or it ain't, lol.
  2. #12
    yeah yeah yeah i know, it'll happen soon enough
    skinny 45 is normal oil pressure
    Simple: 408 on steroids!
    single digits coming soon!
  3. #13
    Oct 2007
    A -6 oil feed line will lower your pressure that or an engine oil cooler.
  4. #14
    thats the motto i go by...right when my truck started knocking...i took it out and went WOT...
    as for oil pressure,as long as u have pressure its all good isnt it lol
  5. #15
    Quote Originally Posted by Tarinitup1 View Post
    that ran from the block off plate on the side of the pan next to the oil filter?
    i mean if its getting enough oil up top i think she'll be fine, just not used to the high oil pressure thats all im saying
  6. #16
    Oct 2007
    Bandera, TX
    [QUOTE=skeet;475281]thanks Mic, so whats great oil pressure?
    Hight pressure is good in my book. I run 20-50 in my lsx, and 15-40 in all my others.
    single digit street truck
    for build info
  7. #17
    Jan 2010
    Cedar Park
    I thought general rule of thumb was 10 psi oil pressure for every 1000RPM engine speed.
    2012 Ford F-150 Ecoboost Super Crew 4x4, stock and staying that way.
    2001 chevy green = LS1 stock, 3k stall, 373 posi, tuned by LSX Power in CS TX
  8. #18
    [QUOTE=TurboMic;475315]
    yeah i run the same 20/50 but break in i been running the 30 weight joe gibbs oil. fixing to change the oil and give it a few pulls and she how she does
    Quote Originally Posted by GraniteBlueNNBS View Post
    i read the same thing my 07 and 09 both run 48 psi on oil . and there stock
  9. #19
    Jan 2010
    Cedar Park
    My 01 ran 48 at idle and would run up to 80 at WOT. That sounds normal..
  10. #20
    My 6.2 runs around 50-55 cold, then warm its 45... wot is over 60.
