security
what would cause the security light to stay on when i am driving
If the BCM notices an inconsistant message coming from the Instrument Panel and the vehicle is already running it will turn the light on and disable the security system until it senses the problem is corrected. Now the problem is if you do nothing to repair it and it goes out on its own well it is only a matter of time before the condition occurs when you are attempting to start the vehicle whitch will put it in anti theft mode meaning it will likely start then stall and the security light will flash for a little over ten minutes at which point you will be able to make another attempt. So if your security light is coming on you should probably have a relearn performed on it just to be safe. good luck
thanks for the info i will try that
It started off as the security lite coming on while driving. Then the security lite would flash on/off when trying to start it. Turned out to be my passlock system. Between it not starting and taking upwards of an hour to start or driving down the highway and it randomly shutting off, then taking the same amount of time to start. This sucked to say the least.
http://www.gmfullsize.com/forum/showthread.php?t=199600
The parts I replaced to resolve my issue.
26049449 is the lock cylinder case w/ ign lock actuator, ign switch actuator and passlock sensor
26075995 is the ignition switch with passlock connector
Thanks for coming back to let us know what fixed it.
- You may not post replies
- You may not edit your posts
