I got a 04 silverado with a cold air intake and a magnaflow dual exhaust. I have a loud drown in the cab at highway speeds thats anonying any suggestions on what to do i dont want to get rid of anything tho.
run the exhaust all the way out the back if its not already or look into a different muffler
2006 Chevy ECSB 5.3 - New L33 Motor,CAI, Descreened MAF, Nelson 93 tune, Transgo Shift Kit, servos, 3in exhaust, Borla, pacetter LT's, and ORY, Aeroforce Furture: stall, cam, 4.10's
Does it sound like an exhaust drone? Could be a u-joint or something around the drive shaft causing it.
Its diffently a drown not the drive shaft exhaust is out the back im on my second muffler and dont want to replace it my first one was alot louder. would a sound deadener work in the cab how much would it deaden it
which magnaflow do you have? mines the 14in case and i have it in front of the wheel with LT's and no cats its loud as hell when accelerating and at WOT but on the highway it really doesnt have a drone
i am not really sure which one it is sounds just like what yo got 14in case i still have the cats and factory manifolds. was thinking about headers and no cats don't need them in south dakota i get a drone when accerlerating and at highway speeds exept for when i hammer down on it then i dont notice it i guess just wanted to get rid of it so i can talk to the person sitting next to me in the cab
Might need a longer case muffler
99 Silverado 1500 4x4 RC 4.8
4L60E, 3.73, Homemade CAI, 92oct Quik tuned,08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
Where is the muffler mounted? You could try moving it back further...
2014 GMC Sierra Crew Cab
-5.3
-Gibson Exhaust
It's located right between the cab and box about as far back as it can go because right after the muffler it the pipes go up and over the axle.
If you are drowning in the cab, you could open the door to lower the water level.
