Thread: A/c clutch turns on and off every 10-15 sec????
    Oct 2009
    Katy ,Texas
    ok well my a/c is still blowing cold but i just noticed that the a/c clutch cycles every 10-15 seconds and my rpms drop 100-300 rpms?? what couls be the issue? its a 06 silverado that i bought brand new and its never had the a/c touched or ever wrecked so i dont think its low on freon . maybe the high pressure switch or something???
    06 silverado crew cab 4.8L
    STS Kit W/turbonetics BB 60-1 .81AR T4 and intercooler 10psi
    Nelson custom tune
    built 4L60E-hopefully it lasts
    2500 stall-Hughes converters
    42LB injectors
    3.5 Magnaflow exhuast
    6inch lift on 35x12.50s
    Plainfield, IL
    Unless the AC is on HIGH, it should cycle. It kicks in til the pressure comes up, then cycles off. 10-15 seconds seems a little excessive though. Check the pressure with a gauge, might be a little low.
    Pull the electrical connector and see if there's any green stuff in it, we've seen the ports/pressure sensors leak over time.
    If there is any freon or die or anything under the connector, it's leaking and needs to be replaced, then refilled.
    Pittsburgh, PA
    does this only occur at idle rpms? if you give it some throttle does it fix it self? if so a few tables in the tune need adjusted
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Oct 2009
    Katy ,Texas
    i only checked it at idle , i havnt givin it gas to see if it changes.
    Nelson custom tune
    42LB injectors
    Oct 2009
    Katy ,Texas
    ok went to look at it and now its working fine ? i guess its my trucks time of the month again .its like clockwork every 1st through 4th day of the month something happens. but im going to hook up some gauges to it tomorrow and see if its low on freon or something.
    Nelson custom tune
    42LB injectors
