Results 1 to 7 of 7
Thread: dtc's
    dtc's
    i pulled b2647 p0102 p0103 p0463
    i know why on two of them. but what causes a p0102 p0103? i installed a ported tb and intake like a month ago and hadn't anything popped up. It was raining real bad... engine runs fine
    Psalms 144:1
    Si vis pacem, para bellum
    why would the maf read low and high? water in connectoins? need cleaned?
    Psalms 144:1
    i've checked the connections to the maf and cleaned it and it still does it. I take it, it needs replaced? somebody chime in here. I've cleared the codes three times now and the light doesn't come back on instantly, but its back on. if i need a new maf, iwhere'd be the best place to get one? autozone, gm or a certain aftermarket company? the truck feels like its shifting hard.
    Psalms 144:1
    those two codes are high and low frequency errors, it's more than likely a bad maf.
    the 463 is evap related and that is a very common problem, it can't be fixed, turn the code off.
    i thought it was the gas gauge?
    Psalms 144:1
    oh ya, it is.
    so you think the maf is bad forsure? any maf better than stock?
    Psalms 144:1
