Thread: Console install Q's
    Nov 2005
    ohio
    I'm thinking AGAIN about putting a full console in my truck which already has the 40/20/40 split bench. What else do i need for it to work? Ive heard a glove box door, and maybe a new A/C duct under the dash? Also if i get one with the Bose amp and sub can i hook it up easy or maybe with some extra wiring from the dealer? Or maybe i could just get a new JL 6'' sub and an aftermarket amp.-Thanks-Tim
    killer swap!!! you need it all !!! take out the seats, remove that thing on the lower part of the dash in the center. install all the console stuff, its not to bad, and the bose system can be installed into the truck, you need it all too, get the 6 disc radio, bose amp, speakers (you might be able to use aftermarket speakers) after installing and wiring it all in, you will need to program the radio to the car, during the programing you will have to fudge the rpa codes to uq7 w/y91 to get the radio to unlock and turn on the bose stuff. i reccomend the denali swap, get the dvd nav player, lower 6 disc, gps antenna, and all the bose, IT HASE TO BE FROM A 04. the nav radio needs no programing, just a vin relearn. i have a bose amp, you can have it when i get your fans in...
    Nov 2005
    ohio
    thats great hummertech! thanks for the pricless info!!! I wasnt quite shure how it would work, billy at TRT had a beautiful center console for sale a little bit ago, i just wasnt sure what was involved but it looks like i can keep my stock seats.
    Jun 2004
    pasadena, tx.
    ok i had the plain jane insides in my truck single cab. i just put in center console and powerseats and carpet. i love it, it took a few hr. but worth it. i didnt get the bose one or cd or anything but it made my truck look so much cleaner and nicer inside. of course 4 me its a 2 seater now but thats y i have a bed right. u need the big plastic peace that goes around the gauges ac and radio though and if u wanna hook up the ac to the back u need the bottom duct. i put it all in myself carpet and all. ull like it alot better. any questions ill b more than glad 2 answer if u want. danny
    04 4.8 FIPK, Pacesetter long tubes, dual exhaust with x-pipe and Dynomax race bullits, gutted cats, 160 therm, hypercrap programmer
    Future mods-p/p thottle body, 02 z06 cam, within the mth. 4:11 g80 soon after......just tryin to blow my tranny
