Results 1 to 10 of 13
Thread: homemade traction bars. what do you think??
    hey guys i just made some traction bars for my truck and just trying to get some input on how they look. tell me what you think......
    Plainfield, IL
    i've never been a fan of them ...but those look better then most aftermarket ones
    Oct 2009
    Albuquerque
    they look good. how do they work?
    They look great. Do you still have full suspension travel without clearance issues?
    casey23 Guest
    Looks like a fab tech ladder bar system to me.... helps with axle wrap.. not sure it will help with Traction
    thanks oleshifty!!! you have to get some!!! the make a huge differance exspecialy with jacked up truckes like ours!!!thanks for liken them!!! they work awsome!! i can kicker down and make the tires make noise now but i cant with till i get my 4.56's in there that i just got in the mail today!! i have now clearance problems at all. ii actully put one on backwards by accident( the big part by the frame) and it just would of cleared. i also have 6inches of lift thought. i did get the idea from the fabtech but wasn't about to spend 600 on them plus the install kit. it did help alot with the axle wrap..thanks for lookn guys!!!
    Plainfield, IL
    What you want for a set?
    were you lookn for looks and to work or just to work??? cuz if you looken for both i could help you out otherwise you could make ones yourself out of a single bar and sill have the same affect. but i also welded ther mounts to the frame and the axle
    Augusta, Ks
    Pm me a price too
    2004 Buell XB12s
    Plainfield, IL
    All the ones i've seen had a plate that bolted where u-bolts go. And then mounted to frame. I'd want function (if you really think it makes a difference) I have some on the front already.
