06-19-2009, 12:49 PM
Speedy
I sure it can be done. But just be careful
__________________
2000 Silverado ECSB- 5.3 CAI, Pacesetter LTs, ORY- Pipe, Magnaflow XL, E-fan, Ported T/B , Nelson Tuned, Built 4l60e, Circle D Stall, 3.42s G80, 2-4 Drop, Hertz Highs, Rockford 501s *Waiting to be Installed* 220/222 .581/.581 114lsa, Magnacharger, 60lb injectors
2007 Hyosung GV650 The Little 650 Cruiser that could. 12.7 at 104 Mph
06-19-2009, 06:59 PM
Senior Member
I'd imagine, pulling it out....supporting the side back sections...removing small chunk (so you still have fabric to wrap around) from center, you SHOULD be able to make it work. Adding/shaping foam if necessary. If you're just doing the back, I don't think you'll lose TOO much.
__________________
 CAI,TB,UD,Straight Pipes,3.73, 10" Lift, 36's, Tow Mirrors, Roll Bar, KCs, z71 Grill
06-19-2009, 07:04 PM
Resident Dick
So does hacking up a back seat that will never hold up once you're done.
__________________
08 RCSB :: Z71 :: 5.3 :: Flowmaster :: Spectre :: Nitrous Outlet :: Virgil Tuned
