04-23-2004, 10:27 PM
Senior Member
wow, what a sleeper, that thing is like a mad max truck or something, very cool!!
I like the rear lights, nice touch for the truck.
I see those 8 lug wheels, damn it is a 3500 ledsled,
good job,
allen
04-23-2004, 10:45 PM
Turbo Moderator
Wow another long bed truck!  That thing is cool! What mods have you done to it?
__________________
2002 GMC Sportside Denali front end with a 2002 LS1, FLT level 5, Yank 2600, Trick Turbo, T76, Nelson intercooler, 60LB injectors, Warbro fuel pump, Eaton locker, Magnaflow, 3.42, Nelson Performance Tuning (speed density).
1981 GMC LB RC 1500 2002 4.8L 4L60E 12 bolt 3.73 Richmond Lock Right AC PS Nelson Performance tuning
04-24-2004, 02:38 AM
Member
As far as engine mods go its pretty much stock, intake setup I have a Lt-1 elbow with a K&N mounted on the end of the MAF. Exhaust is stock manifolds with cats and 2 1/4" duals to the axle with no mufflers, had 2 flo-pro mufflers but it was too quiet and airy sounding, I suppose because I had no x or h pipe. So as an experiment I just chopped them off, its actually not too loud.
As far as drivetrain its got a 4l60E with stock crossmember, stock two piece driveshaft shortened by Advanced Driveline. Original 3.90 gears with only like 300,000 miles on the Generals original fluid, no posi. Still has stock tire size which is hurting me.
Body mods consist of shaved tails, mirrors, tailgate handle and antenna, obviously no emblems or body moldings, sir micheals roll pan welded in and with the lights cut into it. I also have a line of fire led wired as brake and turn signal lights. So all the tails are LED and extremely bright. The mirrors that are on the truck now are actually hot rod mirrors I flipped upside down and mounted high to kind of mimick both an old school look and also the concept SSR. Saddleman flush fit tonneau cover, and a Belltech 5 7 drop to finish it all off.
Interior is still in the works right now, sorry for the long winded post.
__________________
1 ton, 4600 pounds, 14.3@94mph any questions?
04-26-2004, 07:55 PM
Senior Member
its 3/4 ton to?
__________________
old set up: 2002 chevy 5.3, procharger 12lbs boost, asm headers, ls1 edit, flames, 20inch budniks
New Set up: 2004 chevy 5.3 ext cab, 12 inch twisted suspension lift, 36's, exhaust.
future mods: 150-200 shot, ls1 edit, air intake, stall, 5.13 gears, 12s or bust
