Results 1 to 1 of 1
Thread: Moisture in my taillight
    Eastern Idaho
    Some a**hole was kind enough to crease my taillight, not enough to break it out but enough to put a crack in it, now I have moisture inside the lens. The ‘Ho is a 2K, I assume the taillights are a one piece unit, even if I remove the light I won’t be able to separate the pieces to dry out the inside, right? If that is the case I thought one way to fix it would be to take the smallest drill bit I have, poke a hole in the top in an inconspicuous corner, wait until it dries out, then fill the hole with silicone. Any thoughts on this?
    Thanks
