whats the best material for intake mat?
i had 2 hurry up and build a quick intake tube ,so i used a piece of 4 inch exhaust pipe,not too pretty ,and heavy as hell .luckily its only a straight 3 ft piece with a welded bracket,it work fine but id like something lighter and better looking that also would keep cooler.any suggestion or links that would help me out?i saw 1 guy with a piece of corbon fiber how would that work and were do u get 3-4 inch ?open for sugg.thanks
