Results 1 to 10 of 11
Thread: 2005 Silverado suspension lift shock question
    Nov 2009
    chicago, il
    spruce grove, alberta
    they wouldnt hurt but must leveling kits will come with an extender for the shocks
    2000 GMC Sierra
    6" pro comp suspension
    3" body lift
    2.5" truxx leveling kit
    37" micky thompson mtz
    pacesetter long tubes-offroad y-pipe-no cats-morroso muffler-MSD coils and wires-flex a lite fans-air aid intake-diablo tune
    Fort Worth, Texas
    If you plan on cranking the front up 2 inches I'd replace them. The stock shocks will be close to fully extended with the added height, so your ride will suffer. Basically they will max out going over bumps and such driving down the road. Those lifted shock are a bit longer fully extended and would improve the ride quality....
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    Oct 2009
    huntington indiana
    check ebay, that price is kinda salty, you can get them cheaper that come with the brackets to move your shocks up, you would save a bunch of cash and could re use your shocks, but if you need new shocks buy the extended length ones. in my opinion the leveling keyways are all the same.
    procharger p1sc, nelson tune, 42# marine injectors, walbro 255, lt's, ory, 4" volant cat back, PerformaBuilt level 2 pro race trans, trans. cooler with e fan, 2500 stall, aem wideband, energy bushings, spohn perf. trailing and panhard rods, mb & gear alloy 22's ( ya 2 sets, im big ballin), ss brake lines, drilled & slotted rotors, bla bla bla bla bla bla bla,
    and ya it will beat a hemi.
    Nov 2009
    chicago, il
    I was going to get new shocks anyway, I have also heard that alot of people use F150 keys?
    Racoon Twp., PA
    Rough country leveling comes with shocks, blocks, and keys. For under $200, that aint bad.
    99-06 Silverado Rough Country Complete 2" Leveling Kit : eBay Motors (item 300384994732 end time Feb-07-10 09:48:13 PST)
    If you are doing just the keys, then yes Ford keys are the cheapest way to go.
    2013 CC 5.3
    81 C10 LS1 project
    Nov 2009
    chicago, il
    Chevy Silverado Lift Kit - 2" by Tuff Country 1500 1999-2006 (#12923)
    This is really what I want to get, but it would still leave me on a slight rake. Would I be able to crank the front up about an inch, after the keys and add-a-leafs? And if I do, would it really change the ride quality up front all that much?
    Racoon Twp., PA
    Personally I would rather do a 1.5'' block rather than the add-a-leafs. Had em, made the rear bouncy as hell.
    If you crank up too much on the front keys, the problem you have is that when you release your suspension; say like a whoop in the road, you will get a clunk because you hit the stops that stop the control arm from dropping to far down.
    2013 CC 5.3
    81 C10 LS1 project
    Oct 2009
    huntington indiana
    i cranked the keys way up on my silverado and it rode like crap, and also did 1.5" blocks in the rear and it didnt affect the ride or towing in the rear. i would do my homework before i got f150 keys, most 88 up gm keyways are the same if that helps
    Jan 2010
    Lift
    I have a 2002 2500hd, and I did a torsion bar lift, shock extensions, rear add a leaf and a 2" block. I got 3"-3.5" all the way around the truck with factory shocks. They don't like it but it's been a year and still no signs of any leaks or clunks. I would reccomend longer shocks just for extra travel in the suspension.
